richjthorpe
This isn't really to do with LCDs but since I am doing the calibration on and LCD, thought it would be the best place to start !
I understand that the DVE disc is a DVD and you calibrate your DVD player via SCART/Component/DVI for a good picture on that input.
But what if you want to calibrate the input for the Freeview box say ? Do you connect the DVD player to the input used for the freeview and do the calibration again ? Would you use the same settings as the input for the DVD player ?
My problem is that what if there is a difference in equipment settings. For example, using the same settings for a SCART DVD player as for a SCART Freeview box, I would have thought the two pieces of equipment would send out differing signal intensities, eg reds may be stronger on the Freeview box. Which would mean you would need to get a copy of the DVE disc onto the freeview.
Or am I just complicating things ?!
Richie.
Richie.
