DVE and Viera
Discussion in 'Plasma TVs Forum' started by jamesjfa, Sep 16, 2004.
  1. jamesjfa
    jamesjfa
    I am just about to purchase DVE. Can anyone tell me if this is the best way to set up my Viera and Home Cinema system (Pioneer DV99)??
    Thanks again.
  2. jamesjfa
    jamesjfa
    No thoughts on this from anyone???
    Surely someone must have used this DVD??
  3. jamesjfa
    jamesjfa
    OK 117 views and no feedback. If DVE isn't the thing to use can anyone point me in the proper direction.
    Thank you.
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Without wishing to sound rude, if you do a search on this forum you will see that DVE is used by quite a lot of members and regarded as a good product, the search function is easy to use and often under used imho. In terms of DVD product there is only one other alternative called Avia. Is it the best? Well I should imagine that the professional members of this forum will argue the best solution is to get your plasma calibrated by a qualified engineer.
    S.
  5. jamesjfa
    jamesjfa
    Thank you for your honest reply. Order has been placed for DVE now.
