DVDShrink - How to include subtiles on a "foreign" movie
Discussion in 'PS Vita Forum' started by figoagogo, Oct 29, 2005.
Tags:
  1. figoagogo
    figoagogo
    Mar 29, 2005
    8,193
    +579
    If I rip a movie using DVD Shrink (Ong Bak), how do I make it include the subtitles for playing back on my PSP?
    M
  2. rob_finch
    rob_finch
    May 8, 2005
    791
    43
    +94
    On my version (3.2), in the Preferences off the edit menu, the stream selections tab has a Subpicture Language drop down, enabling you to chose all, none or one language.
    HTH,
    Rob.
  3. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    You just check the tick boxes on the right pane of the screen for the video that you have selected (uhhh total no brainer).
    I got a feeling you don't mean that though.
    Are you infact asking how do you get the subtitles from a dvd that you have ripped to display on the PSP?
    In which case, dvdshrink has nothing to do with this you will need to use other programs.
  4. figoagogo
    figoagogo
    Mar 29, 2005
    8,193
    +579
    Cheeky monkey! I know about the tick boxes, its getting the subs to display on the PSP screen :D
  5. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    lol, :hiya:
    sorry mate :)
    Ummm, I'm not exactly sure how to do it off hand as I haven't got me large memory card yet but its not that hard, used to do it for svcds on me old dvd player years ago for some foreign stuff i liked.
    Best bet would be to go to the forums on http://www.pspvideo9.com they'll defo be able to tell you the answer.
    soz I can't help ya right now I'm a little busy with some furniture moving to look it up. :eek:
  6. figoagogo
    figoagogo
    Mar 29, 2005
    8,193
    +579
    Thats OK, may try Decrypter, its perhaps some kind of streaming process with the subtitles enabled.
  7. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    I'm pretty sure the PSP doesn't support selectable subtitles for user encoded video so basically, its not stream processing in the ripping program thats important - because the subtitles will have to be hard coded into the video - there's programs that encode the video and subtitles into one stream.
    This is not related to DVD Decrypter\Shrink (although when you start out with these programs - obviously you select to include subtitles but thats as far as these programs will take you)
    Its a fairly complicated procedure compared to say ripping a dvd with shrink.#
    Not doubting you mate!!!! just letting ya know.
    I'm really sorry I just can't remember the exact proggies I used to use been out the loop too long...I'm sure others will help you if you ask them...
    "How do I encode subtitles onto the video to be viewed on the PSP" Ask that in pspvideo9 forum.
    soz if i'm patronising you!!!! :)
  8. figoagogo
    figoagogo
    Mar 29, 2005
    8,193
    +579
    OK - think I will leave it, this DVD ripping and converting is all a bit slow and time consuming for me :thumbsdow
  9. psikey
    psikey
    Oct 5, 2005
    8,275
    3
    South Yorkshire
    +1,445
    I read up a lot on this for the same film plust House of the flying daggers.
    Apparently it is quite difficult and looked that I would have to use 3 or 4 separate programmes to do it. I also gave up!
  10. figoagogo
    figoagogo
    Mar 29, 2005
    8,193
    +579
    :rotfl: Is it really that hard oh well, at least I have HOFD on UMD :D
