Dvd's .vob File Problems
Discussion in 'Movie Forum' started by DanAshmoreUK, Feb 24, 2003.
  1. DanAshmoreUK
    DanAshmoreUK
    hey there
    Ok ive ripped a vob file from my DVD now how do i put it onto a CD-R as an MPEG Multichannel? The vob file i can rip down to one .DTS file or a DTS .WAV and an .m2v file using VobRator.
    Now first of all how do i combine them together? What software is needed and how would i do this? Also is there anyway other way then making an MPEG Multichannel file such as VCD SVCD?
    I wanted it to be very high quality too and dont really wanna lose that DTS sound:(
    Another thing it would be better using the DTS .wav file so that i can decode it as Multi c 3/2.1 instead of PCM? Please I really need help here guys!:confused:
    thx
    ---Ashmore---
  2. DanAshmoreUK
    DanAshmoreUK
    anyone plz
  3. Sgt.Colon
    Sgt.Colon
    Have a look for a program called TMPEGEnc. That will allow you to do it.
    you could try www.digital-digest.com
    plenty of help there :)
  4. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    For any help on this try vcdhelp
    This covers just about everything you can imagine
