DVDR questions..
Discussion in 'Blu-ray & DVD Players & Recorders' started by Alexaqui, Dec 12, 2003.
  1. Alexaqui
    Alexaqui
    Hi all. I'm new to this forum. I've been browsing the many threads and I have a couple of questions.
    Is there a succint listing of what all the different DVD recording types are and what the pros/cons are? (ie, +/-, etc)
    Based on what I have read, it looks like most DVDR's can only record 1 hour in quality mode or 2 hours in standard mode. Is this correct? Is it possible to record 3+ hours on a DVDR? If so, how would the quality be.
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Dependant on how fussy you are about quality,2.5 hours is really the max you want to put on a disc if its something important,or a good movie.But you can go up to 6 hours if you're really desperate,but the quality suffers.Picture quality versus storage capacity is equal for all formats.Take a look through the "sticky" at the top of this section
