DVDR media question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Tim_UK, Feb 26, 2005.
  1. Tim_UK
    Tim_UK
    Aug 13, 2003
    34
    I've got a Pioneer DVDR 5100 recorder and usually use 4x DVDR discs in this.
    Is there any problem in using 8x media in this machine (I realize it would not write at the faster speed) as this would enable me to buy the same media for use in this recorder and my computer DVD recorder.
    I know there used to be problems when using 2x media in 1x recorders but am not sure if the same issues arise with the faster discs.
    Thanks for any advice anyone can provide on this.
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Using 8X should not be a problem. I use 8x discs on both my Toshiba XS32 (which is a 4x machine) as well as my PC DVD writer (which is also 4x max). In fact it's hard to find 4x media these days...
    Mark
