Dvdr-, Dvdr+
Discussion in 'Computer Components' started by Tony Roma, Nov 17, 2003.
  1. Tony Roma
    Tony Roma
    Oct 4, 2003
    1,923
    Essex
    +48
    I am thinking of getting a DVD Recorder for my pc, what are the differences between dvdr- and dvdr+ discs, and would it be better to buy a drive that can use both, forgive my ignorance on this, i am fairly new to Computers.....Cheers
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
  3. BBD
    BBD
    Mar 13, 2001
    430
    Lutterworth
    +3
    SVP communications are selling the excellent Pioneer 106s for $86inc VAT (oem version) .So how much are you actually going to save by buying a single format drive?
  4. Kramer
    Kramer
    £80 inc. from Dabs :eek:
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,197
    Argyll
    +2,257
    From PC useage there is very little difference between plus and minus formats. The former (plus) has a few technical advantages that debatably make it more reliable when burning, but most minus drives have had improvements made to the basic design which have equalled or (in Pioneer's case) improved upon them.
    Given the cost of dual-format drives you might as well opt for one of those. Good models are available from Pioneer (106, A06):
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=49638
    ...and Sony:
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=52123
    If there is any likelihood of you buying a set-top DVD recorder in the lifespan of the drive/computer you should seriously think about an all format drive such as:
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=54794
  6. Tony Roma
    Tony Roma
    Oct 4, 2003
    1,923
    Essex
    +48
    Cheers for the advice, i am considering the pioneer which looks good value.
  7. daveyboy
    daveyboy
    I bought the Pioneer 106 from Dabs about a month ago and paid over £100 then.:mad:
    Can't believe how much it has reduced in such a short space of time but the burner was great value at the price i paid so i would definitely recommend the purchase.
