dvdpacific & customs?
Greg Hook
Moderator & Reviewer
Check the Customs sticky for full information, but to just confirm if the item is under £18 before postage, you won't be stung. If it is over £18 before postage you will get stung for the whole amount including postage.
P
pags payback
you should also allow a little variation in curreny rate fluxuation(spelling?)
Glib
DVD Pacific do not include shipping costs in their customs declarations so you don't need to worry about that as part of the total costs for customs. Great disc by the way!
Matt Horne
Yes but Hm Customs will...
krish
OnTheFly
All members should be aware that whatever the exchange rate is on the first day of the month, that is the rate the Post Office will use for the entire month. I know the rate only fluctuates slightly both ways - usually. A couple of months back it didn't. Ouch!
johnone
hi guys
did anyone else notice something in the last budget about doing away with custom charges on usa imports or was it the pills
nictry
johnone said:
hi guys
Must have been the pills, this must be a highly lucrative income generator bearing in mind the British public has finally realised how ripped off we are in this country and now import bucket loads of electrical type products from the US. Can't see them dropping import limits full stop and the leats likely location, in my view, would be the US :(
Similar threads
