jkharmer
Established Member
Are there any major differences in PQ between these brands? Looking to connect one into my Pio 436XDE, with SDI in from dvd and freeview in also. Would the preferred connection to the media box be through a dvi cable?
What are the implications of buying through a none recognised dealer - if it broke, would you in effect be left with no warranty (have seen some advertised by a German guy on eBay)?
James
James
