DVDO VP Scalers - HDMI Switching
Discussion in 'Projectors, Screens & Video Processors' started by roman-r, Jun 17, 2009.
  1. roman-r
    roman-r
    Jun 11, 2004
    6,394
    83
    London - Stoke Newington N16
    +195
    My VP50 has never managed to switch between HDMI inputs. Happy to switch between cmponent and will always pick up the HDMI from my Bluray but ignores my HDMIs from 360 and HD-DVD.
    I thing my BR is plugged into the 2nd HDMI socket.
    Have found the urge to try and fix this so can anyone confirm if their DVDO VPxx can switch or better still can resolve my problem :D
  2. itsdusty
    itsdusty
    Oct 25, 2006
    13
    3
    Jersey
    +3
    Hi, yes I have managed to use all four HDMI inputs switching between them, Sky HD, Foxsat HDR, PS3 and Home Theartre PC. However periodically an input fails for no apparent reason. A few months ago a firmware upgrade got them all working again. At the moment only inputs 1 and 3 are working despite upgrading to v1.09 a few weeks ago. I believe my problems are to do with HDCP handshake. When working auto switching goes to the input of the unit activated, although I have programmed my universal remote control to select the input as part of the switch on routine. All sound is also switched via the VP50 with one output to my amplifyer.
    Dusty
  3. roman-r
    roman-r
    Jun 11, 2004
    6,394
    83
    +195
    Thanks Dusty
    It's what I had thought.
    Anyone else actually have it working without fail ?
  4. roman-r
    roman-r
    Jun 11, 2004
    6,394
    83
    +195
    Do we not like to critercise our beloved DVDO A/C Hub :eek:
    Com on guys, does HDMI switching work or not :devil:
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Can't say I every had any problems with my VP50-Pro doing HDMI input switching.
    But then I never have Auto Switching enabled, does that make a difference?
    StooMonster
  6. roman-r
    roman-r
    Jun 11, 2004
    6,394
    83
    +195
    A little confused with this.
    So the VP50 Pro auto switches between HDMI without you using auto switching ? How does that work ?
    The Auto input button is what is meant to be pressed to have "in theory" any input automatically swithched to based on your own preset input Heirarchy.
    Is it the "Auto" input button you are refering to as being enabled?
    Roman
  7. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    You didn't say you wanted auto-switching in the first post ;)
    although I guessed that's what you meant.
  8. roman-r
    roman-r
    Jun 11, 2004
    6,394
    83
    +195
    Thanks Choddo.
    Does your VP50 auto switch between HDMI ?
    cheers
    Roman
  9. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Sorry, I don't know, never used Auto. I'll try to remember to give it a try. I'm pretty sure that SkyHD is "greedy" and will always keep its signal awake which keeps the vp50 stuck on that input if it's high up the priority list - perhaps your bluray deck is similar?
  10. scumball
    scumball
    Jan 12, 2004
    6,511
    Harrow - London
    +449
    The Sony S350 does when using Quick Start I believe...not sure which player roman is using...
  11. roman-r
    roman-r
    Jun 11, 2004
    6,394
    83
    +195
    I actually have all my players completely off so they're definately not effecting each other.
    Strange so few seem to be interested in the feature as I was hoping at the very least lots would say it didn't work and I could bring up with DVDO.
  12. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    I reckon most vp50 owners use remotes with macros.
  13. roman-r
    roman-r
    Jun 11, 2004
    6,394
    83
    +195
    I do to, but auto switching would still simplify things
