I have a DVDO VP50 and use it with my Mitsubishi HC5000 to which the Scaler outputs 1080p.
As inputs I have SKYTV (italy) at 1080i/50 and DVD at 576i/50 (plus an AppleTV).
I cannot manage to change the OUTPUT FRAMERATE in the VP50 to (locked) 50Hz.
The output is always 59.94. If I try to correct it manually or choosing "50 locked", I loose the picture.
Connecting the input sources directly to the Projector works as expected since the Mitsubishy obviously accepts the inputs at 50hz.
Anyone can solve the strange problem?
Contacts to DVDO support only managed to produce e-mails with obvious information copied from the manual and no practical use.
Loris
Loris
