DVDO Switch
Discussion in 'Cables & Switches' started by kocl, Apr 4, 2016.
Tags:
  1. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    I have a DVDO Q6 running in AVR Mode that connect to my Anhtem 710.
    It happens very often that when switching between sources its shows only a blue screen. I don’t show image in any source despite de green led light.
    I must switch off and on the DVD0 to work again.
    What could be the problem?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    'What could be the problem?' - the Source, the Switch, the AVR, the Cables or the Display; take your pick.
    Is the Switch on the Input or Output side of the AVR?
    Is one Source more prone to the Blue Screen than others?
    Do you ever suffer the Blue Screen if you remove the Switch and go - Source > AVR > Display?
    How about Source > Switch > Display - any issues if you try that combination?
    Joe
  3. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
