DDRUK_Lawrence
I have a PixelMagic MB200 HD MediaBox, a DVDO iScanHD and a Panasonic TH-42PWD6BX with VGA input. The iScan outputs from the VGA out in RGB to the Panny. Now according to the DVDO website (see links provided below for further info) I can use the DVI input and process 480p/576p signals which can be output as an analog component, analog RGBHV, or DVI signal. I bought an HDMI to DVI lead and connected the HDMI output of the MB200 to the DVI input in the iScan. I have set the Configuration / DVI Input to Auto on the iScan menu. I have set the MB200 to output HDMI - 576p. However, no matter what I try I can not get the iScan to process the signal. It is always 'Passthrough' and this means it outputs on the DVI and not the analogue VGA to which my plasma sceen is connected.
Before I return my HDMI - DVI lead does anyone have any suggestions to get the iScan to process this signal? I am pretty sure the HDMI output from the MB200 is not protected.
Thanks,
Lawrence.
Reference Links:
MB200 - http://www.pixelmagicsystems.com/products/media_players/hd_mediabox.htm
ftp://ftp.crystalio.com/Public/download/HDMB_Owners_Guide_1.0.pdf
iScanHD - http://www.dvdo.com/faq/faq_ishd.php#faq_hd3
Thanks,
Lawrence.
Reference Links:
