DVDO iScan HD+ - what exactly does it do?
Discussion in 'Projectors, Screens & Video Processors' started by Stampax, Aug 7, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,405
    Northampton
    +88
    Im about to buy a new plasma and have seen this mentioned in the plasma forums - i was just wodnering if anyone could explaian exactly what it does can i basically connect it to my plasma and then everything else (dvd player, games consoles, etc) plugs into this, and makes the PQ 10 times better????
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,746
    The Borders
    +3,085
    Stampax
    In a word NO - an external Video Processor is used to bring together a range of source signals and optimise each signal to your Display (or Displays).
    Whilst every Display device has its own on-board Video Processing these are often fairly rudimentary and by utilising an external Video Processor with high quality processing you aim to arrive at a better image quality across a range of source signals.
    Achieving a ten fold improvement in image quality with a low bite rate MPEG2 file would be a miracle - though its pretty obvious when you see a properly installed and configured system that includes the likes of an iSCanHD+ that the iScan is a fair bit better than what the Display manufacturer has provided.
    None of these products are Plug and Play - they all rely on YOU configuring the Video Processor to best match your Display device and also to best match each source device you plug into the Video Processor.
    If your experienced at setting this type of kit up then fine - if not ensure you work with a Dealer who can.
    Best regards
    Joe
  3. Stampax
    Stampax
    May 6, 2005
    1,405
    Northampton
    +88
    Thanks Joe - much appreciated!
