DVDO Iscan HD/Sky+ - being an optical thicky
Discussion in 'Projectors, Screens & Video Processors' started by BillBailey, Dec 5, 2004.
  1. BillBailey
    BillBailey
    Nov 20, 2004
    12
    Have just installed my new Iscan & Panny HD7. I'm getting pretty good results but some more tweaking is required. However, having never used optical cable before, I can't figure out how to connect my Sky+ box digital audio output to the Iscan.
    I have been supplied with a Toslink cable which looks as though it should plug into the Iscan, but won't. I'm a bit reluctant to force it in, but is that what is required? At the Sky+ end the socket seems to be different, ie 6mm square with a pull out cover. Have I been supplied with the wrong cable?
    Any help will be gratefully received as I need to use the Iscan's audio synch capability.
  2. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    The connectors have a key on the them, try rotating them.
    On the Sky+ box, pull the blanking plug out , the IScan has shutters on its socket.
    Oh just remembered, on an IXOS optical lead i bought, it had a little clear rubber boot protecting the fibre optic cable, need to make sure those are taken off.
  3. BillBailey
    BillBailey
    Nov 20, 2004
    12
    Of course you were correct Laura - it was the rubber covers that threw me. Well, I am a man - what do you expect?
    Now, how do I plug in the mains lead? The socket has 1 hole at the the top and 2 at the bottom. The plug has 2 pins at the top and 1 at bottom. I mean, it just defies logic!!! ;)
    Bill
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    Bill u have to break out the Black and Decker and saw that little B8stard in 2, then glue it back together the opposite way, should look great for a plug when done :smashin:
