DVDO Air Wireless 1080p/3D/7.1 Audio Transmitter
hodg100
The rather funky looking DVDO Air wireless HDMI connection system is the latest in a line of wire-free 1080p transmission systems we’ve seen recently. It’s also capable of 3D images together with 7.1 channel lossless surround sound too. It connects any source with a HDMI output to a HDMI port on the HDTV/display.
DVDO says many HD Wireless systems compress the HD signal and some don’t work with all HDMI features. DVDO Air is fully HDMI compliant, capable of delivering uncompressed 1080p video and 7.1 surround sound, 3D and Consumer Electronics Control (allows the TV remote to control the source device).
Running at 60GHz, DVDO’s 'Air' system comprises a transmitter, which installs at the source, and a receiver that clips on or behind a display using the bracket supplied. The set-up entails powering the system down; replacing the HDMI cable with DVDO Air; mounting the receiver, and powering up – and that’s it!. The solution offers a wall-mountable alternative to long cable. DVDO says connection is good from a few metres away or within a large room from up to 30 meters.
Specifications
• 60GHz band – 6 channels available
• Supports up to 3D 1080p
• Latency 2ms
• Max throughput 4Gbps
• WiHD certified
• Inputs/Outputs: HDMI 1.4a with CEC support
• HDCP 2.0
• Range up to 10m non line of sight; up to 30m line of sight
• 2D support: 480i/p, 720p, 1080i, 1080p, 7ch surround
• 3D support: 720p 50/59.94/60. 1080p 23.98/24
• Frame packing Side by Side, Top/Bottom, Sensio, RealID
• Audio: 8ch PCM up to 192kHz, Dolby 5.1 up to 48kHz.
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
