Quantcast
Dvd89 and 3802
john R1
Have ordered my dv89 from creative audio simply because of the great price they are offering, will i be able to play the dvd-audio via my 3802 and what connecting lead will i need await your replys
SamirP
Yes you will be able to play dvd-A disks using your 3802 just connect the DV89 multi-channel out to the EXT. IN input on your amp with a set of multi channel cables (3xpairs Phono leads)
Check out Mark Grants powerbuy on multi-channel cables
