DVD32R won't start up.
Discussion in 'Blu-ray & DVD Players & Recorders' started by parky43007, Aug 26, 2006.
Tags:
  1. parky43007
    parky43007
    Oct 8, 2003
    235
    Tarragona
    +16
    Well after 3 and a half years my DVD32R has packed in.
    It just wont start up - it is totally dead. Changed the fuse but to no avail.
    Anyone any idea what the problem might be and the likely cost to repair??:lease:
    Shaun
  2. laidbackman
    laidbackman
    Aug 16, 2006
    493
    +25
    Sorry, contact should be made using this email address, not the above my appollogies to Kevin, Mods please remove the previous reply
    [email protected]
    LBM.
  3. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    I believe that Kevin doesn't do DVD32R's, they're a bit of a pain to work on! Best bet is contact IAG and let them take the pain instead! ;o) If the thing is totally dead then typically it will be a PSU issue, hence not mega bucks.
    Steve
  4. parky43007
    parky43007
    Oct 8, 2003
    235
    Tarragona
    +16
    Thanks,
    I'll give IAG a call tomorrow - hope your are right and it ain't gonna be megabucks!
