dvd32r software upgrade
Discussion in 'TAG McLaren Audio Owners' Forum' started by chiefski26, May 14, 2005.
  1. chiefski26
    chiefski26
    hi all
    i have a dvd32r and would appreciate details on how to update the software and what is needed.
    many thanks
    sukh
  2. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    Download the latest software from http://www.iaguk.com/tma/tmaindex.htm and also the tma upgrade wizard program
    and then the hard part finding a cheap TMA update cable which i believe is now nearly £100
    try ebay first (for a cheap cable)or depends where you are a local forum member maybe able to help :thumbsup:
  3. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    but then again what is your software version at the moment
    i do not think any more software updates will happen so the cost of a cable will be very costly
    the software version you have will be shown briefly in the front display on power up
  4. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    when you click the link iag.com goto helpdesk the latest dvd32R software is V 3.85
  5. chiefski26
    chiefski26
    hi,
    thanks for quick reply!!!!!!!!! im in london
    software is 3.75
    is it worth upgrading?
    cheers
  6. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
    Try and borrow someone's cable but until then you should be fine! Can't remember what changed. :eek:
  7. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    wasn't the difference between V3.75 and V3.85 something to do with the psm upgrade :confused:
  8. mabu
    mabu
    Mar 10, 2010
    140
    +3
    Same question... Are there any information what changed from 3.75 or 3.76 (in my case) to latest 3.85?
    Isn't it possible to make my own upgrade cable from a common serial cable? I read somewhere about the AV32R that the upgrade cable is just a RS485 standard?
  9. canavan
    canavan
    May 30, 2004
    103
    +7
    Since you're in Germany, you can borrow my cable. Either pick it up in or near Cologne, or email me a prepaid DHL shipping label, and ship it back when you're done.
