Dvd32r+psm
Discussion in 'TAG McLaren Audio Owners' Forum' started by sjon, Mar 26, 2005.
  1. sjon
    sjon
    Mar 9, 2005
    23
    3
    Hello all,
    I have the possibility of buying a DVD32R, built in march 2003.
    Were all problems solved at this time, with the door/drive of
    this player?
    Is there anybody wo knows this?
    Thank in advance for all your help.
    Greetings
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    The firmware revision will tell you about the drive fitted, if it says S58, it is the new mech. As for door issues, if it opens and closes smoothly then it will be OK but perfect maybe not but it isn't a big thing really......
  3. benzol
    benzol
    Mar 16, 2005
    385
    Europe
    +22
    Is the S58 always ensuring that the new drive mechanism is build in the player?
    Meaning a player with older firmware (3.7) would have the new drive if S58 pops up?
    Benzol
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    As far as anyone knows, yes. The S stood for the later Sanyo mech!
  5. benzol
    benzol
    Mar 16, 2005
    385
    Europe
    +22
    Thanks for reassuring.
    Benzol
