fortisflyer75
Established Member
I now have the DVD32R with Prog scan module and did not realize until receiving it that Prog scan does not operate from the RGB component outputs and has to be from either the BNC or DVI-I output for Prog scan to work.
With not been to familiar with either of these types of connections and knowing they are not so easy to get hold of which is my best connector type to go with? - Not just on the DVD32R output but also the input end on my Pioneer Kuro which has either RGB component or HDMI.
I am thinking; do I go with DVI-I to HDMI or component or BNC to Component (or HDMI if this is available!?) .....Or possibly even a DVI to HDMI adaptor plug then connect any HDMI cable that way but unsure if using this method there is any degradation in quality doing this.
Confused as to which would be best as I have heard from someone that it is widely contested by some quarters that DVI and BNC are better than the other not to mention whether it would be whether it would be more beneficial to go HDMI over component on the plasma picture input.
Any help would be grateful as it seems trying to track down a good quality cable will be hard also as eBay has a lot of non branded cheaper cables on there which are a unknown quality.
