dvd32r picture problem
Discussion in 'TAG McLaren Audio Owners' Forum' started by xa200, Jun 1, 2005.
  1. xa200
    xa200
    My dvd32r has developed a strange problem through the component outputs. The picture stays pink continously. However using svhs the picture is fine. The picture is pink for both component outputs and i have no idea why. I have tried a differnt cable to no avail. The unit is a standard unit without the psm module. Does anyone have any idea as i don't want to be without it while the service department tries to sort it out.
    thanks
  2. roversd1
    roversd1
    Hi there
    My memory is a little rusty regarding the video settings on the DVD32R, but I think your display device may have reverted back to expecting an 'RGB' signal.
    Investigate this first, that should cure it.
  3. hmuller
    hmuller
    May 31, 2005
    60
    11
    Warfield
    +10
    Hi xa200,
    Silly question but have you selected the component output setting in the DVD32R menu. If its still left on composite/s-video then I believe that some of the component connections are used for a split (higher quality) S-video type of connection using BNC connectors and that results in a pink display on a component TV input.
    hans
  4. roversd1
    roversd1
    The DVD32R has 3 video chips, so you can only have s-video/ composite or component.
  5. abspag
    abspag
    The pink colour indicates thst your Interlaced component is only available via the RCA "phono" connectors.
    The fact that your display is pink means that this display device is capable of displaying non interlaced signals.
    Use the remote commands to change from RGB or COMPONENT out and this will rectify the pink picture.
  6. abspag
    abspag
    Sorry slight mistake component is available from the BNCs when the psm is not fitted
  7. xa200
    xa200
    Thanks for your replies. It was due to svhs being selected in dvd menu. I don't know how it happened but since i havn't changed the menu of the dvd player for over a year i didn't even think about it. Well thanks for you help.
    :smashin:
  8. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Alls well that ends well.
