DVD32R master reset - anyone know how?
Discussion in 'TAG McLaren Audio Owners' Forum' started by Black 5, Jul 2, 2005.
  1. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    I'm hoping it's not going to be a bigger problem, but my DVD32R started playing up tonight after years of faithful service. Spins cds OK, but I can't navigate menus in dvds and the tagtronic bus seems to have gone awol, not synchronising blue led and switch off. Sounds like it may be the dreaded failure on its way, but I thought a master reset first and if that doesn't do the trick, a reinstal of 3.85 may help.
    Anyone know how to do the reset?
  2. Miron
    Miron
    Sep 26, 2002
    1,428
    Vienna, Austria
    +53
    Hi Brian,
    hold "Skip" and "Display" at power on
  3. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    Thanks Miron. I haven't done this yet as today the unit is working perfectly :confused:
    I've just realised how lost I would be if my dvd32r collapsed and I was without it indefinitely - methinks I'll buy a second one to keep for hopefully many years from now when they are no longer available/can be repaired!
