dvd32r color problem/DVI problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by jugla3, Mar 14, 2006.
Tags:
  1. jugla3
    jugla3
    hi! wen i am put my dvd32r conect s video, i am don't see red color, wen connect dvi all desplay pink. who know what problem is???
  2. Keith @ SG
    Keith @ SG
    if i understand you correctly, check your DVD32R on-screen menu - you need to change the output setting - to RGB if i remember correctly,
  3. Mics49
    Mics49
    Jul 30, 2004
    958
    28
    +58
    Edit after checking:
    - no disc in tray (player switched on of course)
    - press '742' (actually stands for 'RGB' as '266' would stand for COMponent)
    on your remote
    Oh, and welcome here mate! :thumbsup:
  4. jugla3
    jugla3
    HI! I AM HAVE DVD32R WITH PSM192. BUT I AM CAN'T USED DVI OUTPUT. WEN I AM USE MY SCREEN PINK.
    IN VIDEO SETUP MENU JUST 2 OPTION.
    1. S-VIDEO+COMPOZIT
    2. COMPONENT
    WHO CAN HELP. WILL WERRY APRISHIATED. THANKS.:lease:
  5. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
  6. Mics49
    Mics49
    Jul 30, 2004
    958
    28
    +58
    all PM'ed mate. let us know how it works out. :thumbsup:
