DVD32 -> Panny 6 Plasma DVI problems - Help!
Discussion in 'TAG McLaren Audio Owners' Forum' started by lovegroova, Sep 27, 2004.
  1. lovegroova
    lovegroova
    Jul 15, 2002
    2,731
    103
    Herts
    +388
    I have just bought a 2nd hand DVI board for my Panny. I have installed it in slot 1 and have some problems:
    With the DVI board in slot 1, I can't get a signal via the component board in slot 2.
    The DVI output only seems to work if the DVD32 is outputting an NTSC signal. PAL produces a 'digital mess'.
    Even with the DVD output set to NTSC, I don't get a signal via the DVI when using an s-video input to the PSM.
    DVD32 with PSM is running software version 3.85.
    Any help you can give would be much appreciated.
