DVD32 OSD Bug
Discussion in 'TAG McLaren Audio Owners' Forum' started by Tantalus, Jan 21, 2005.
  1. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    Just noticed a strange one.
    DVD32FLR connected to plasma via component.
    Change volume - and the volume db are shown on screen bottom left. Ok.
    I press the centre button - once I get some details of track time etc - press it a second time and I get surround format. Then again and they disappear. Fine. No problem.
    But after doing this - I try and change volume again and it doesn't show on screen.
    Can anyone confirm this?
    [I don't suppose I'll ever see a fix anyway... but it's irritating!] :thumbsdow
  2. tedy
    tedy
    That is an old bug.Press pause and play again and everything will be back to normal.
  3. Miron
    Miron
    Sep 26, 2002
    1,433
    Vienna, Austria
    +53
    Few of us (I think Theodor was the first one, almost one and a half years ago) reported this bug few times, unfortunately it was never corrected.
  4. PhilB1234
    PhilB1234
    I've always noticed it, but never knew there was a way round it, so thanks for bringing it up Tantalus!!
  5. sijones
    sijones
    Nov 5, 2001
    632
    Reading
    +34
    I use the 'THX' button on the remote (in DVD mode) and this forces it back on as it causes a 'not allowed....' message to be displayed. This is better than using the pause and play workaround.
    Regards,
    Steve
  6. Miron
    Miron
    Sep 26, 2002
    1,433
    Vienna, Austria
    +53
    Yes Steve, the same here, I also use it as a best workaround button. I think it was Paul who wrote it on old forum first. Or it was you, (can't remember anymore). I know only Tedy was the first one to report the bug.
