DVD32 Interlaced to SCART - Possible?
lovegroova
Currently I have my PSM equipped DVD32R connected via the progressive output to my plasma, but also would like to connect it using the interlaced outputs to a SCART equipped TV in another room using RGB rather than s-video.
Can anyone recommend a lead which would allow me to do this, or is it more complicated than that?
I guess I'd need to switch the output of the DVD32R from YUV to RGB for it to have any chance of working???
Thanks in advance...
EDIT: Would this do the trick? http://www.tvcables.co.uk/cgi-bin/tvcables/YUV-RGB-SCART.htmlEDIT again: Bum, just noticed that the RGB/YUV option is only available from the PSM outputs...
any ideas would be welcomed.
