DVD write speed problem
Discussion in 'Desktop & Laptop Computers Forum' started by steviewilson, Jul 28, 2005.
  1. steviewilson
    steviewilson
    Dec 18, 2004
    Glasgow
    Just bought a new LG burner, allegedly read write speeds of up to 16x, but I burned the 1st disk and it wouldnt show higher write speed than 4X. Its 8X media and my pioneer 107 I have just replaced wrote at 8X no probs. I just needed a drive to recognise ram disks. All cables and settings are identical to the way the Pioneer was setup. Any clues?
    Stevie
  2. KoThreads
    KoThreads
    Jan 18, 2005
    2,978
    +164
    Try updating the firmware. My LG's firmware was way out of date when I bought it and acted the same.
  3. steviewilson
    steviewilson
    Dec 18, 2004
    Glasgow
    Did that mate and still only lists 4x options. Hmmm.....
    Stevie
  4. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    Stevie
    I had much the same problem when I upgraded to a DL/16x speed Sony. The same media that burned perfectly at 8X on my older drive resolutely failed to burn beyond 6X, even with the latest firmware patch. Left me with half a spindle that I had to use up at lower speed than before I bought the new drive! :mad:
    I just bought several different brand 16X discs from Ketta or ARPMedia (or similar retailers) - just 1 of each so not much outlay - and found which ones burn at 16X.
    For me it was Infiniti and Verbatim by the way. Imation and Philips are no good in my drive.
    Slightly off the track of your problem, but hope this helps :D
