DVD with VGA
Discussion in 'Blu-ray & DVD Players & Recorders' started by figlio, May 21, 2004.
  1. figlio
    figlio
    Dec 17, 2002
    180
    Malta
    Can you tell me some DVD players that have VGA output
  2. jmack
    jmack
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    but officially it is illegal
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    for what reason? The encryption thing?
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    the only variant of RGB that is allowed is the one used by SCARTS :)(). From memory this is RGsB, RGBHV which is what were are talking about re VGA is verboden, you need to look component (which is related!!). Basically it is one of those daft things
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    sounds daft indeed! It isnt even with reason like the encryption!
    ad
  7. a3rmk
    a3rmk
    Jan 17, 2004
    286
    Essex
    +6
    lektropacks.co.uk have a magic box, part no.csr-2200, for £49 that turns a scart RGB into a VGA output but check compatibility.
    I have one that i use from my XBOX into the plasma and it works fine.
  8. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    There are a lot of cheap chinese players with vga output but models destined for the uk often have it removed and a scart rgb socket in its place. Normally the h/sync and v/sync points are still available on the circuit board to make a conversion cable but you often also need a new firmware with the vga enabled option as scart rgb only uses a combined v/h sync.
    You can find however chinese spec players about with the vga output option fitted. They are often imported by uk wholesalers directly and sold through small dealers or professional ebay auction sellers.
    Also dvd players like the kiss dp450 have a vga option using a converter cable but it doesn't work with commercial macrovision protected dvds. It does with non macrovision dvds though. You can get round this problem using an earlier firmware but then you lose the excellent performance and improved divx compatibility which the later firmware has.
