DVD with single digital out & DAC
Discussion in 'Hi-Fi Stereo Systems & Separates' started by witters, May 15, 2004.
  1. witters
    witters
    Jul 13, 2000
    12,651
    Yorkshire
    +293
    My Pioneer 370 has only a co-axial digital output but I want to use it with a Meridian DAC. Is there any way to split the co-ax signal to use it with both my AV amp & the DAC please?
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    You need a "splitter" Witters there were a few coaxial splitters a couple of years ago on the market but cant seem to find them on the net these days the nearest I can find is toslink ones :
    http://www.lektropacks.co.uk/dept.asp?Hash=168&dept_id=109
    Ie convert from Coaxial > toslink > 3 way toslink splitter, you should find one though (Ive looked at Maplins & Lektropaks and no joy in coaxial terms) but there is another company worth trying called Keene Electronics they might have what you need.
    Left field suggestion here cant you feed the 370 directly into the yammie AV amp and feed out towards the 203 in coaxial terms ?
    Anyway good luck.
  3. witters
    witters
    Jul 13, 2000
    12,651
    Yorkshire
    +293
    Thanks for that - I'll have a look.
