DVD with simultaneous analog & digital output
Discussion in 'Blu-ray & DVD Players & Recorders' started by nevC, Mar 3, 2005.
  1. nevC
    nevC
    Oct 13, 2002
    109
    Ireland
    Anyone know if there is a player that simultaneously outputs both an RGB or S-video and a digital signal, either DVI-D or HDMI? I don't want to have to swap leads every time I switch from projector to TV. Does Denon 2910 have dual output?
    Any help would be appreciated
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    I think the problem with outputting Digital and analogue is that when outputting digital, the Prog Scan is also turned on. Since the player cannot send a Prog Scan signal over RGB or S-Video, you wont be able to view through Scart/S-Video.
    Are you wanting to view both the PJ and TV at the same time ? If not, doens't the 2910 have a button on the from for Digital ? (I know the 1910 has one for DVI). If so, you can turn the Digital off when watching the TV and back on when watching the PJ. Just connect everything up.
    Richie.
  3. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    The 2910 can output analogue and digital together, but you may find with digital on analogue becomes jerky but on the remote you have a button to toggle the digital on and off.
  4. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    The 2910 has excellent digital (DVI/HDMI) and analogue (Component) outputs, both available by toggling between them on the remote - piece of cake to operate.
  5. nevC
    nevC
    Oct 13, 2002
    109
    Ireland
    Thanks for the info. Had hoped not to have to go into the system menu of the player every time in order to change output. I don't need to use TV and PJ simultaneously so a button on the remote is very convenient.
    Cheers,
    Nev
