Dvd with 5.1 dtds out
Discussion in 'Blu-ray & DVD Players & Recorders' started by tommy tac, Jan 15, 2002.
  1. tommy tac
    tommy tac
    I have just purchased a wharfedale M5 from tesco. I connected 6 phonos to my sony amp (no processor). There is a buzz from the front speakers during quite scenes in films. I know the amp and cables are Ok so, I am taking the DVD back tommorow for a refund.
    Can anyone recommend an alternative DVD player with 5.1 and DTS decoder between £100 - £200.
    I was thinking of £99 Cyberhome from richer sounds but this has had some poor reviews on this site.
    I cannot find anthing else in this price range that has an on board decoder.
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    It looks like you´ll need to increase your budget and move towards a more expensive player. Alternatively, get yourself another amp/receiver with its own decoders built in and get something like the Toshiba 210 dvd.
    The Toshiba is available from 150 upwards (multiregion) & you can pick up amps etc from 250 quid.
    There are some 2nd hand bargains around as well, in the Classified Hardware section are a couple of Denon 3300 for 200 quid each. Older models but still excellent sound, especially at that price.
    Hope this helps.
  3. Guest
    I bought the Acoustic Solutions DVD-551 from Richer Sounds (£119) and although the first player had a fault and had to be returned its replacement has functioned perfectly for 4 months. The remote's design is a bit antiquated but fully-functional.
    It has a built-in decoder and both analogue and digital (coax & optic) outputs. It also reads CDR/CDRW and plays MP3.
    Richer Sounds offer multi-region at extra cost and hand over an A4 photocopy detailing the hack so I wouldn't bother and get it from here if you need it.
  4. Guest
  5. damtom1
    damtom1
    RICHER SOUNDS ARE RAVING ABOUT THE LG 4950,THIS COMES WITH AN ON BOARD DECODER.COST £199.LOOKS THE BIZ ASWELL!
    WHY NOT BUY ONE OF THEIR SHERWOOD AMPS AND BUY ANOTHER DVD PLAYER WITHOUT THE ON BOARD DECODER.THE LIMIT OR LG ARE AROUND £100.
  6. tommy tac
    tommy tac
    My internet has been cut off for a few days. I bought the LG model before I read any of these replys. It had 5 red stars in what hifi. It is also a very solid player. Build quality is suberb, much better than the plastic M5. The sound is also really good. The buzzing evident with the wharfedale has completley gone.
    I picked it up for 199 at richer sounds in Cardiff.
    Since I had the amp and 5 seakers givven to me. I had to repair the amp dry joints. I now a complete DTS/5.1 sytem for 199. not Bad. Now I just need to buy a 32" TV.
  7. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    I also like the LG, even though my local branch of Richer Sounds is doing their best to disuade people from purchasing this player and distracting them with those toss Limit players. Bloody *****.
