DVD With 5.1 Audio outputs
Discussion in 'Blu-ray & DVD Players & Recorders' started by Whippy, Oct 23, 2005.
  1. Whippy
    Whippy
    Hi, I am looking for a dvd player that has 5.1 audio outputs, as I have a now old Sony amp that has 5.1 audio inputs. ( i.e. 5 off rca connectors ) so I am looking for a dvd player that has a built in decoder and the 5 audio connectoras on the back. Any suggestions, recommendations??
    Ian
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    A large percentage of DVD players have built in decoders and 5.1 analogue RCA outputs. If the player is listed as being able to play DVD-A or SACD then it must have these outputs as these formats can only normally be decoded by the player and output to an amp via the RCA connections.
    What is your budget for the DVD player? With this we will be able to offer some advice as to what is good in your price range.
    Mark.
  3. rhino2k
    rhino2k
    Oct 20, 2005
    6,128
    +1,322
    pioneer dv-575a :smashin:
  4. magicmushrooms
    magicmushrooms
    I'm considering the pioneer dv585 & Yamaha DVDS657 DVD, they both have the 5.1 connections you require
  5. mjbtin
    mjbtin
    Jan 13, 2005
    2,497
    116
    +645
    The limit dvda900se has 5.1 outputs,and the audio side has been tuned by british high end specialists Cyrus.This player has excellent pq and superb audio and is currently being sold on www.play.com for the bargain price of £49.99 delivered.
  6. Whippy
    Whippy
    Thanks all for your suggestions, My budget is about £100.
  7. rhino2k
    rhino2k
    Oct 20, 2005
    6,128
    +1,322
    dv575 is £120 in richer sounds, and reported to be better than the new 585 :smashin: you'll find it is a very highly rated player :cool:
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    A good few to choose from in your pricerange Here
    Mark.
  9. Dr Armitage
    Dr Armitage
    I just sent my Limit DVD player back to Play. The CD audio was horrible, and the paicture juddered when playing R1 DVDs. Still looking for a good all round player under £100 with optical out...
  10. mjbtin
    mjbtin
    Jan 13, 2005
    2,497
    116
    +645
    On the limit when playing r1 dvds you have to set the player to ntsc or auto,if set to pal the picture will judder.As for cd audio being 'horrible' this implies that the guys at Cyrus do not have any idea what they are doing.You do not mention what the rest of your setup is,this probably is the cause of your horrible cd audio
  11. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    I can recommend the pio575a, good build, good price, good name, great player !!
  12. Dr Armitage
    Dr Armitage
    Thanks for the info Stevedster. Pdbmjb get your head out of your arse.
  13. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    i have to say, being tuned by cyrus doesnt mean a lot, if the components used in the first place suck, they can tune it as much as they like, wont mean it sounds much better than any other player around its price range....lol
    if its supposed to sound almost as good as a Cyrus model then either Cyrus have dropped their standards waaaaay low, or they are waaaay overcharging...heh
  14. Dr Armitage
    Dr Armitage
    Yes, and the power button fell off 10 minutes out of the box -- and it wouldn't play my dual discs.
  15. the mechanic
    the mechanic
    Nov 30, 2003
    1,232
    Wrexham,North Wales
    +53
    Better still in this months what hi-fi the RS advert still lists the 575 as £99.95.
    This is a special price for readers of the mag, so be sure to quote it when you enquire about buying one.
    Given the price the 575 has to be the best DVD players around IMHO.
    If bought from RS it will be multiregioned outta the box, play almost any disc thrown at it apart from DVD-RAM, and DVD-A & SACD playback is great.
    Picture quality thru PROG-SCAN component output is fan-bl**dy-tastic, (make sure you use decent component leads if you go down this route though), and it has been said that the component output is better than some players equipped with HDMI outputs in the budget end of the market.
    Go out and buy with confidence, for a hundred quid you can't go wrong.
    Graham.
