dvd vs hd
Discussion in 'Blu-ray & DVD Players & Recorders' started by PaulBudrow, Mar 31, 2005.
  1. PaulBudrow
    PaulBudrow
    I just hooked up my new prog scan dvd player to my philips plasma. Is DVD image quality slightly less sharp then HD picture? The DVD picture is fabulous but just not as sharp as my HD channels.
    I saw an dvd that converted HD signal. Would that result in a clearer picture?
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,256
    48
    London
    +97
    HD is a higher definition than DVD and therefore will give better picture - you can get DVD players that will upscale to HD definition but this of cause is not going to be as good as a source that is HD in its native format (you can also buy external scalers).
    Until the HD/blu-ray DVD players become available the picture is unlikely to be as good as a high bitrate broadcast HD programme
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    The softness is caused by the scaling being done by the plasma, which will always happen unless you have a display of the same resolution as the video you're playing.
    As Astaroth says, you can get DVD players that do the scaling instead of the display however softening will still occur, you can't eliminate it only minimise it.
