DVD via S-Video problems with Denon 2307: Help wanted
Discussion in 'AV Receivers & Amplifiers' started by Scapegoat, Apr 26, 2007.
Tags:
  1. Scapegoat
    Scapegoat
    Nov 19, 2004
    2,638
    Leeds
    +137
    Have connected my DVD/HDD recorder via S-Video cable to the Denon 2307 amp (waiting on a component cable to arrive).
    However I cannot get it to to display on the screen (though I can get the sound).
  2. pils
    pils
    Jan 11, 2007
    104
    +5
    Have you run an s-video cable to your screen from the monitor output or enabled the correct upconversion if you're using component or HDMI?
  3. Scapegoat
    Scapegoat
    Nov 19, 2004
    2,638
    Leeds
    +137
    S-video in to the AMP (along with 1 x HDMI, 2 x componment), and just the one HDMI cable up to the TV.
    Optical and coaxial cables from inputs to the amp for sound.
    I think that I have obviously not enabled the correct upconversion for the S-video input - any suggetions on how to do this?
  4. Scapegoat
    Scapegoat
    Nov 19, 2004
    2,638
    Leeds
    +137
    Gone into the system menu.
    Oddly the DVD can be seen behind the white text.
    If I go to menu system I can assign HDMI and Component inputs to various funcntions on the AMP, but I cannot seem to select S-Video inputs.
    If I got to Video Convert Menu I can turn it on/off under DVD/TV/VCR-1/VCR-2/V.Aux. Its on for all off them.
    HDMI out setup - Analog to HDMI Convert is ON.
    HELP
    The manual is rather confusing...
  5. Scapegoat
    Scapegoat
    Nov 19, 2004
    2,638
    Leeds
    +137
    Gave up in the end and bought a component cable.
