DVD-VCR-HDD Combi or separates?
Discussion in 'Blu-ray & DVD Players & Recorders' started by colin148, Feb 6, 2009.
  1. colin148
    colin148
    Jan 15, 2009
    Just bought new home TV room set up, and want to ensure I can get all the old family VHS tapes playable and better still copied to DVD.
    Option A) a DVD rec / VHS Player
    Option B) DVD Rec / HDD / VHS recorder
    Option C) DVD Rec / and a seperate VHS player that could be put away in a cupboard once all tapes are copied, ( year 2012 seems a possibility..)
    - But would their be an issue with synchronisng the recording etc etc...?
    Last option, is to Copy all tapes from a VHS player to PC, then make a DVD and play back through a DVD Payer..
    Whats the best option as I dont want to have too much kit, but on other hand the risk of a 3 way combi going kaput would mean a lot of dosh wasted. Whereas a standa alone VHS player would be cheap ( if I could find one anywhere?)
    guidance please.....
  2. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    the last option is best
    a sony , pioneer or panasonic hdd/dvd recorder as you will use most or all of its functions
    and buy a cheap vcr if you havent already got one , and transfer footage from vcr to the dvdr hdd , edit , and then transfer to dvd disks
    and scrap the vcr when finished ( or put it away with the tapes , just in case )
