DVD-VCR Combos - RBG out?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paul Reading, Sep 9, 2003.
  1. Paul Reading
    Paul Reading
    Feb 2, 2003
    96
    I cannot buy a high quality VCR no one seems to make them anymore, the only ones which apprear to be high quality are DVD-Combo units.
    Are/do any of the current models available provide RGB out for VCR material or do they only provide it for DVD sources.
    Secondly can anyone recommend a unit with a high quality video, I already have an Arcam DVD so I am not interested in that part of the unit.
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Vhs and svhs videos record the luminance and chroma signals seperately. So s-video is the highest quality connection you can get out of them. Only recorders based on higher technology like d-vhs, dvds or hard drives are capble of giving out rgb signals. If you buy a dvd-vcr combo the vcr section will more than likely just give out a composite or s-video image even if the dvd section can give out a rgb image.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    The best you'll get out of all DVD/VCR's that I'm aware of is composite from the VCR section, but the DVD can usually output RGB and S-VHS.
    I'd suggest you hunt down an S-VHS VCR which should be even cheaper than the combo units.
