DVD/VCR Combis
Discussion in 'General TV Discussions Forum' started by handyandy, Jan 9, 2005.
  1. handyandy
    handyandy
    Can anybody recommend a good quality easy to use dvd/vcr combo? I haven’t got any experience of them myself and a quick look on the internet at a couple of reviews of the latest for Sony (D930) and Panasonic (NVVP31) seem unfavourable. I was also looking at the Philips DVP620 but can’t find any info on this.
    I have been roped into buying it for a relative and the most important factors are picture performance (seems to be what is letting them down, especially vcr), ease of use and reliability. A mass of connectivity is not important.
    If anybody can recommend a good unit I would be very grateful.
  2. Slapnut
    Slapnut
    I was in the same predicament over Christmas and spent a lot of time researching all the available models. I found that the features I wanted from the VCR (i.e. VideoPlus, NICAM, PDC) was not always available with the features I wanted from a DVD Player (DivX, Multiregion, Progressive Scan).
    In the end I opted for the Toshiba SD34VB from RGBDirect.co.uk for £130 which has the award winning SD340 DivX DVD player coupled with a fantastic feature-filled VCR. Its now retailing for £145 but some popular companies are still selling this model for £270+ (see Digital Direct as an example)
    If the features mentioned above arent important to your buying decision- look out for cheaper models available through Richer Sounds and Argos. Otherwise definitely plump for the Toshiba.
  3. handyandy
    handyandy
    Slapnut, Thanks for your help. I hadn't seen the Toshiba before - it is a smart looking bit of kit!
  4. samlees2002
    samlees2002
    Am looking for a dvd / tv combi for under £200.00, but need to know if possible do they all record? And which ones have fast text? Which one would you reccommend for a good price?
    Many thanks
  5. Slapnut
    Slapnut
    It certainly is! Would look great in any lounge. Ive had the system since December and it works fantastically well! Its played every DivX/Multiregion DVD ive thrown at it and the picture looks fantastic through just the RGB Scart (havent tried it with the component output yet- looking forward to seeing that!) The VCR does its job really well too.
    I had another family member see the unit- he was so impressed he bought one himself!
  6. monopole
    monopole
    Anyone got the handset hack to make this multi-region? Sadly, mine isn't multi-region out of the box.
