DVD/VCR combi
Discussion in 'Blu-ray & DVD Players & Recorders' started by scrapbook, Jan 13, 2003.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    Does anyone have a DVD/VCR combi?
    I was looking at models from Sony/Panasonic/JVC/Toshiba.
    Any comments/advice?
  2. jock2
    jock2
    Check out the LG-DVP1000 multible features, looks great,
    Got mine for £199
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
    Bought the tosh for my mother in law...very good on VCR and DVD
    the panasonic is slightly better but about £60 more...
    JJ
  4. iwatkins
    iwatkins
    Got the JVC (about a year or so ago).
    I've had no problems, the DVD is adequate and the VCR is good. VCR has all the toys such as PDC/VideoPlus etc.
    Ian
  5. jock2
    jock2
    Specifications
    Colour Silver
    System -
    Broadcasting System (DVD) PAL
    Broadcasting System (VCR) PAL I
    System Select (VCR) OSD Menu
    Video System [Initial] (DVD) PAL Only
    Video System [Initial] (VCR) [Auto]/ PAL/ MESECAM
    Playable Disc Format -
    DVD (PAL)/DVD (NTSC) Yes
    Audio-CD / CD-R/RW / MP3 CD Yes
    GUI/OSD -
    Graphic User Interface (DVD) Yes
    Graphic User Interface (VCR) (Icon OSD)
    Language (DVD) E/S/F/G/I
    Language (VCR) E/S/F/G/I/D
    Deck Mechanism (VCR) D35
    Playback and Record - VCR -
    Tape Speed (Play/Rec) SP/LP
    NTSC Playback on PAL TV Yes
    MESECAM Auto
    VCR Tuner -
    Type FS
    Channel Range VHF E02~12
    Channel Range UHF E21~69
    Channel Range CATV S01~20
    Channel Range Hyper Band S21~41
    Channel Add/Erase Yes
    Channel Auto Search Yes
    Channel Memory 88
    Default RF Out Channel Ch 36
    Video Head 4 Head
    Recording Mode SP/LP
    Auto Channel Set-up Yes
    VCR Audio -
    Audio Head/Hi-Fi Audio Head Y/Y
    Hi-Fi Stereo Y
    NICAM Stereo/A2 Y/Y
    DVD Video -
    Video DAC 27MHz/ 10 Bit
    DVD Audio -
    2ch Downmixed Audio Out Yes
    Audio DAC 96KHz/ 24 Bit
    DTS Support Yes
    3D Surround Sound Yes
    MP3 Decoding Yes
    DVD Convenience -
    Zoom Yes
    Marker Yes (9EA)
    Marker search Yes
    Screen Saver Yes
    Last Condition Memory (1EA) Yes
    Smooth Scan & Slow Yes
    Repeat/Program/Random Yes
    Parental Lock Yes
    100x Scan Yes
    VCR Convenience -
    Timer Record/ITR/Just Fit Record 1 month 7P/Yes/ Yes
    OSD Icon
    VPS/PDC Yes
    ACSS Yes
    Optimum Picture Response Yes
    NTSC PB on PAL TV Yes
    DVD to VCR Direct Yes
    Recording (Dubbing) - VCR -
    Auto Eject Yes
    Counter Reset/Memory Yes/Yes
    Auto Tracking Yes
    Rewind Time 180 +/- 30sec
    Still/Slow Yes/Yes
    Back-up 1 Year
    VCP Search -
    Cue/Rev PAL SP: x7, LP: x9
    Cue/Rev NTSC SP: x5, LP: x9, EP: x15
    Logic Search Yes
    CM Skip (Commercial Scan) Yes
    Digital Shuttle (RCU) Yes
    Other Convenience -
    Simultaneous Operation Yes
    (DVD Playback while VCR Rec) -
    Simultaneous Playback (DVD & VHS) Yes
    Child Lock Yes
    Auto Dimmer Yes
    Function OSD On/Off (VCR) Yes
    Auto Play Yes
    Front Panel -
    Display Fluorescent LCD
    Power button Yes
    DVD/VCR Indicate LED Yes
    DVD/VCR Select Yes
    Open/Close (DVD) Open/Close
    Open/Close (VCR) Eject
    Play (DVD) Yes
    Stop (DVD) Yes
    Pause/Step (DVD) Yes
    Scan/Skip (DVD) Yes
    REC (VCR) Yes
    CH. Up/Down (VCR) Yes
    Front Panel AV (VCR) Yes
    Rear Panel -
    Analog Audio Out (DVD) Yes (1 set)
    Analog Audio Out (VCR) Yes (Scart)
    Analog Audio In (VCR) Yes (Scart)
    Composite Video In (VCR) Yes (Scart)
    Digital Audio Out Coaxial (DVD) Yes
    Digital Audio Out Optical -
    Video Out Composite Out (DVD) Yes (1 set)
    Video Out Composite Out (VCR) Yes (Scart)
    Video Out RF Out (VCR) Yes
    Scart 1 (DVD) Yes (Composite/RGB)
    Scart 2 (VCR Yes (Premiere)
    Accessories -
    RCU Normal/MBR/Shuttle Normal
    RF Cable Yes
    Scart Cable Yes
    Battery Yes
    Owners Manual Yes
    Power -
    Power (V) 200~240
    Consumption (W) 23W
    Net Weight and Dimensions -
    Net Weight (kg) 5.3
    Net Dimensions : W x H x D (mm) 430 x 94 x 345
  6. NIIK_TT
    NIIK_TT
    The LG combi aint all that. It has not got SVid out. It looks nice thats for sure but the picture quality is reflected in the price.
    I bought it from Argos and returned it same day.
    I would recommend getting seperate Video and DVD. I have tried the combis and while its less wires but should one unit break down you are hardly going to want to use the other unit with half of it working and end up chucking it away. So you loose money on both instead of one.
