DVd upgrade for plasma????
Discussion in 'Blu-ray & DVD Players & Recorders' started by TopMeTom, Sep 28, 2003.
  1. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    I have an 'old' 717 pioneer,works perfectly well,but i am upgrading to plasma from a 32 philips.
    So is it worth upgrading to a different player,if so what do you recommend?
    I will be getting the av-sales panny 6 package which comes with a quinttro scart switcher,so no rush to upgrade yet...
    Phil:zonked:
  2. IanM
    IanM
    Dec 17, 2002
    158
    +5
    If your plasma has a DVI input, then it might be worth waiting until players with DVI outputs become more common. Whilst they are not guaranteed to be better than "normal" component players (especially in combination with an expensive video processor), the fact that everything is kept in the digital domain is definitely an advantage. The early ones such as the Momitsu/Bravo seem to give great pictures but also appear somewhat buggy, but hopefully some of the big players will get in on the act soon.
    Cheers,
    Ian.
  3. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Phil, I had a 717 and embarked on the "upgrade" path to my subsequent chagrin. I've been through four players since and nothing, to my eyes, has performed as well as the 717 which I now bitterly regret junking. Sound is a different issue and there are many more versatile players out there, but if picture quality is your prime concern I strongly recommend you don't scratch your upgraditis!
  4. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    Cheers guys,maybe i'll stick with the 717 for now then:)
    Phil
  5. Nick Laslett
    Nick Laslett
    Oct 9, 2002
    I have a 42" Panny plasma, standard definition. Because this only has 480 lines all PAL DVDs are downscaled to fit the resolution on the screen.
    It is very hard to tell the differene between DVD players, although I would recommend upgrading to prog scan as this is less tiring on the eyes.
