DVD upgrade advice needed.....Please !
Discussion in 'Blu-ray & DVD Players & Recorders' started by jonnyv, Apr 14, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,320
    48
    +59
    I have a sony DVP-s725d dvd player multi region, macro vision disabled etc...
    This player got great reviews in what hi-fi..
    I am looking to upgrade the player, does anyone have any sugestions as to what player to go for ?
    I dont need progressive scan, And prefer a pure NTSC output, and an rgb loop through scart..the ability to play cdr's is a bonus..
    the spec of my current player..is here..
    http://www.techtronics.com/uk/shop/50-sony-dvp-s725d-725-multi-region-dvd-player.html
    I am very happy with picture quality..and no lip sync problems..
    any suggestions..?
  2. philipb
    philipb
    Mar 6, 2002
    2,100
    63
    Swindon
    +175
    You don't say what your budget is, but if you talking about £700 upwards then the tosh 900, sony 9000 (which i have - a gem), the Arcam and Denon are all great machines. If a little less then the new Pioneer 747 is getting great reviews and so too the tosh 500. Above about £500 they all do progressive via component, etc. Some even do progressive PAL.
