L
leagro
Another "How do I connect things" question!
I've got the following kit
Currently, I've connected the sky box to the philips, & then the philips to the TV both using scart. This seems to work ok, (a bit fiidly having to remember to select the correct source on the Philips system to get sky).
Would it still be beneficial to connect the sky box to the dvd system with an optical lead?
Is this the usual way to set it up, or would i be better connecting both the dvd & sky direct to the tv with 2 scart leads & then use a 3rd scart to connect sky to dvd (again, perhaps also using an optical cable)?
My sony has 3 scart sockets, but unfortuantely i can't find the manual to confirm if\how many RGB scart sockets it has http://www.avforums.com/forums/newthread.php?do=newthread&f=123#
Mad
Appreciate any comments.
kieron
- Sony 32" CRT
- Philips LX7500 all-in-one system
- SKY+ (V2)
Mad
kieron
