DVD - TV connections which is best?
Discussion in 'General TV Discussions Forum' started by Gary D, Jan 9, 2002.
  1. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    can one of you lovely people please advise me which is the best way to connected a DVD player to a TV?
    I currently use SCART. but would composite video or S-video be better?
  2. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    1st RGB SCART
    2nd S-Video SCART/Mini Din
    3rd Composite (only use as a last resort)
    HTH
  3. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    1st = component video (if you've got it)
  4. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    so we have one vote for RGB SCART and one for composite video does anyone have a casting vote?
    Thanks for the replies.
    Gary
  5. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    No, we have zero votes for composite. And are v unlikely to get any more.
    We have 1 vote for component (which is very similar to RGB) and we have 1 vote ror RGB.
    I didn't mention component because I assumed your DVD and/or TV didn't support it.
    The smart money is on RGB with S-video as an also ran.
    Composite won't even get a look in.
  6. Guest
    I think you have one for RGB and one for component...not composite :0)
    Composite is cheap and nasty..and very different from component.
    You can't use component unless you have a supporting projector or TV (probably a Toshiba..since not many manufacturers provide this option).
    I had a Tosh RPTV with component connections - I couldn't see any difference between them and an IXOS £50 SCART gold SCART lead on RGB.
    IF your telly doesn't do component - go for RGB SCART !
    Daz
  7. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    Assuming COMPONENT is N/A.
    Latest...
    RGB 2
    S-Video 0
    Composite 0
  8. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    thanks to you for replying. i think i'll stick with my RGB scart connection and save the money thats burning a hole in my pocket for something else.
    thanks
    Gary
  9. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    Make sure you use a good qaulity, fully 21 pin configured SCART cable.
  10. Doubledoom
    Doubledoom
    RGB is best nearly all the time. However, there are some televisions that don't handle it too well. Older Tosh models, are a good example.
    You have a scart lead so check for yourself and make your own mind up. The scart carries RGB and s-video so no cost is involved apart from the time you make to compare the two.
