dvd tv combinations - Advice please - confused female
Discussion in 'Home Cinema Buying & Building' started by samlees2002, Jan 9, 2005.
  1. samlees2002
    samlees2002
    Am looking for a dvd / tv combi for under £200.00, but need to know if possible do they all record? And which ones have fast text? Which one would you reccommend for a good price?
    Many thanks
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Dear SamLees,
    You're probably in the wrong bit of the forum here, but I understand why you posted your question here! I'll answer anyway.
    No TV/DVD combo's record onto DVD at the moment. Certainly none that I am aware of.
    If you need to make recordings from the TV and you want an all-in-one setup you'll have to stick with a TV/VHS recorder. The only way to record onto DVD's at the moment is either with a computer or with a commercially available DVD Recorder/Player. See the appropriate DVD Recorder forum for more info on them.
    For more info on TV Combis Try searching with Google.
    Hope this is of help.
    Jimmy
  3. The_Wierd
    The_Wierd
    May 2, 2002
    1,131
    Lancashire
    +316
    After a quick look I see Comet have a Thomson 21" combi for just under £200.
    We have the TV only version of this in our bedroom and it has a very nice picture and is quite attractive to look at. I don't know what the DVD player is like, but it might be worth a look.
    Regards,
    Wierd
  4. Krance
    Krance
    Hi Sam,
    don't think you will get a combo to record at all. You have probably read that they have DVD-R, DVD+R, DVD+RW etc. this only means they will play them... not record them
