DVD to projector cable required
Discussion in 'Cables & Switches' started by vijver, Jul 28, 2004.
  1. vijver
    vijver
    i've just won(!) a BenQ ds550 projector that i want to hook up to my JVC xa-sa72 dvd. the dvd has video and s-video out as well as your usual scart, optical, coax and av compu link jacks. the pj only has a vga input.
    i'm sure it's a question been asked before - but where do i get such a cable and are the signals all compatible?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    depending on PJ you can convert RGB scart to VGA try JS technology converter or a ProV box
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,522
    Somewhere in South Yorkshire
    +5,996
  4. vijver
    vijver
    that spec isn't misleading, it's just wrong :[email protected]
    thanks for your suggestions
  5. vijver
    vijver
    to be fair to benq, i have just discovered that an av box is missing and should have arrived with the pj. this will obviously allow a straightforward connection. as if you care
