DVD to play CD+G (Karaoke)
Discussion in 'Blu-ray & DVD Players & Recorders' started by Sad Sack, Jan 8, 2002.
  1. Sad Sack
    Sad Sack
    Can anyone tell me of a DVD player capable of playing CD+G (Karaoke) discs as well as DVD CDR and all the norms?
  2. Cliff
    Cliff
    Mar 17, 2001
    5,870
    167
    Kent & overseas
    +3,180
    Your in luck as there is another sad person out here who knows the answer.
    First off avoid all cheap decks based on computer drives - usually from China. These strip off the CDG stream. Usually the PCM data is there but without the subchannel data.
    I have tried the Cyberchrome and an LG from Richer sounds and they do not work. The first, BTY is useless at playing VCD's
    Go for the Pioneer DV-343 or 340. Graphics code is in good shape and it reads CDRs CDRWs and unfinalized disks. It is also a good well known make!
    Richer sound advertise a region 2 for £119 - but it's never in stock! (It's just to get your attention) You can get the all region model for £149 . Output is coax.
    Happy singing
    Cliff
  3. mjn
    mjn
    May 24, 2001
    22,227
    Herts, England
    +10,059
    Reads "unfinalized discs", i very much doubt it, as these discs do not have any TOC (Table of Contents) on them!!
    Only CD-R machines are able to do this.
  4. Cliff
    Cliff
    Mar 17, 2001
    5,870
    167
    Kent & overseas
    +3,180
    The wonders of technology!
    It says on their website it can play unfinalised
    Not tried it myself!
    Twin wave Laser Pickup- separate laser diodes optimised for DVD and CD, with CD-R/RW playback (also plays un-finalised CD-R's)
    See www.pioneer.co.uk
    Cliff
