DVD to PC For Editing
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by w4yne, Jun 21, 2004.
  1. w4yne
    w4yne
    May 9, 2004
    40
    Wales
    What would be the best way of getting a DVD onto PC for editing as I have a disc off a friend with three chapters but if you try to use the search or goto feature when playing chapter 3 it just goes back to the start of the chapter.
    If I transfered it back onto pc and then re authored it would it fix this ?
    Thanks.
  2. Stormz
    Stormz
    You`ll have to get a dvd ripping software (Like `Amigoo` iirc), so do a search for that to start off with, which will rip the dvd structure back to AVI files. Then you`ll have to reconstruct the whole dvd the way you like it and burn it again (`TMPGenc dvd author` is the best atm I think).
  3. Brian110507
    Brian110507
    Assuming that the DVD has been made by you or your friend and is not a commercially DVD with copyright protection then you can import it to Ulead videostudio 8 and re-edit and re-author and burn it anew.
    A free trial of UVS8 can be found at www.ulead.co.uk
