Was this post blanked out because of what Mitch was asking? Because I need to know the exact same thing!
I've been asked to produce a small compilation of clips for a launch party and need to use scenes from DVD's. I've tried hooking up my Sony VX2100E to the DVD player but I get a 'Copy Inhibit' warning and it doesn't work. I tried taping to video and then hooking up the camcorder but again it doesn't work.
The problem is that if you get the 'Copy Inhibit' message then you are obviously trying to copy material that is covered by copyright and it is therefore illegal.
You may well be able to get hold of hardware to put between the DVD player and your camcorder to remove anti piracy protection, but this is likely to cost a fair bit. Or you could get a DVD player that has the protection removed, or a hack for your DVD player. Or another option would be to create the compilation on a PC with software that allows the copying of protected video.
Martin,
in theory what you say is correct except that most programs will not allow you to extract copyrighted files. If you have freeware etc programs then these may well be ok, but anything you buy from a shop/internet site is likely to be tied down by the law.
DVDShrink creates an image file when you rip a DVD, so that wont work AFAIK.
if you run it through a video mixer (eg panasonic mx50) it should strip the macrovision.
not that I want to endorse or encourage illicit use of copyrighted material.
