DVD to match Denon + Sonus Faber setup
Discussion in 'Blu-ray & DVD Players & Recorders' started by ngsm, Feb 7, 2002.
  1. ngsm
    ngsm
    Hi!
    I started "building" my home cinema system.
    At this moment I have a Sony 32'' TV + Denon 3802 + a pair of Sonus Faber Concerto Home + a budget DVD Player.
    I intended to buy the rest of the speakers, and change the DVD Player only after that, but I changed my mind.
    I don't want to spend too much money, because everyday new DVD players are released, cheaper and better.
    I'm thinking about something under £500.
    Thanks,
    Nuno
    P.S. - I forgot to say... I need a multiregion player, 'cause most of my DVD are R1.
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,163
    38
    Australia
    +18
    The 'obvious' choice would be the Denon DVD-2800 which is basically a good player and a good match for your amp (if a bit over your budget)..but see the other thread regarding some players having artifacts and give the player you buy a good check out in the shop first.
    Regards,
    Ian Guinan
  3. Lowrider
    Lowrider
    I had the Arcam DV88 with the Concertos, and they match very well, if you listen to CDs too, thats what I recomend, also it plays everything and is upgradable, but it is over your budget...
    If you are in Portugal you could get mine, used, from Digisom...
  4. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    lowrider please give me your thoughts on your your arcam fmj27
    do you use progressive pal&ntsc?
    whats it connected too?
    how much better is it than the diva ??
    is the picture any better??
    thanks
    jason
  5. Guest
    I think Antonio is right
    Arcam DV88.
    One of the best music / movies machine around.....
    Should see a few cheaper prices now the FMJ DV27 is on the prowl...
    Adzman
