DVD to CD
Discussion in 'Movie Forum' started by Zog, Apr 22, 2002.
  1. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
  2. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    It works but it's bloody slow.
    It copies the DVD to a VCD file that fit's on a CD-R. On my Pentium III with 256 of RAM it took 22 hours !
  3. john87
    john87
    How can the quality match DVD like they claim? That must be an utter lie.
  4. dorgan
    dorgan
    Why not try DVDExtractor for the Mac for 'backing up' DVD's. This allows you to make an image of the original and you can burn it to a DVD using toast. This is fine for single layer disks and takes about an hour from launching DVDExtractor to ejecting the finished DVD, you then obviously have an exact copy of the original with menus etc intact. DVD-R blank media has really come down in price, £1 to £2.
  5. encaser
    encaser
    Mar 15, 2001
    1,566
    Suffolk/Essex
    +112
    I've heard dup-dvd is good and very simple to use.
  6. bishman
    bishman
    Mar 29, 2001
    4,902
    83
    hertford
    +172
    Looks to me like it will use DIVX, which I believe is MPEG4, with an MP3 audio compression. Don't hold out much hope of being able to play these on a stand alone DVD player though. Far better quality than VCD, but not quite as good as DVD.
